Quick Set/Reset Current Lister Format
After reading through this relevant and enlightening FAQ entry I created a menu button which provides a pick list of existing formats and quick access to edit folder formats within Preferences.
Regards, AB
Note: The code in the following append by Ken Alcock is undoubtedly an improvement on mine, so use instead.
<?xml version="1.0"?>
<button>
	<guid>{6B9572A5-2C94-4BB1-9024-A0D367F26E8F}</guid>
	<label>Lister Appearance</label>
	<tip>Menu of Lister View Formats</tip>
	<icon1>212</icon1>
	<button>
		<guid>{84C63261-BB06-42B5-AA91-5F93BA88D866}</guid>
		<label>List View Formats</label>
		<tip>Popup List of View Formats</tip>
		<icon1>212</icon1>
		<function>
			<instruction>Properties FORMATLIST</instruction>
		</function>
	</button>
	<button>
		<guid>{F47F268E-6574-48F8-8AF3-7F6135E61312}</guid>
		<label>Edit View Formats</label>
		<tip>Edit View Formats</tip>
		<icon1>212</icon1>
		<function>
			<instruction>Prefs FORMATLIST</instruction>
		</function>
	</button>
</button>
aussieboykie:
I just wanted to point out that your button code above cannot be copied-and-pasted. I believe the XML code was changed during the post [by the old forum software].
In the mean time, I have a Menu-Button with nearly the same (perhaps a little more even) on it that folks can use.
<button display="both" effect="saturate" type="menu_button">
	<guid>{FCF9CCDB-CAAF-48B6-A4BB-E978EFEDE0F7}</guid>
	<label>Folder Formats</label>
	<tip>Preferences – Folder Page: Edit Folder Formats and other folder-related settings.</tip>
	<icon1>119</icon1>
	<function type="normal">
		<instruction>Prefs PAGE=folders,1</instruction>
	</function>
	<button display="both" effect="gray">
		<guid>{4BFD5A31-8B40-47D6-A9EF-20CCE33250B4}</guid>
		<icon1>86</icon1>
		</function>
	</button>
	<button display="both" effect="saturate" separate="yes">
		<guid>{0141D521-3D5E-4F12-B04F-32FD35EFD9E0}</guid>
		<label>Reset to Folder Format</label>
		<tip>Reset Folder Options to those saved in the Folder Format for the listed folder.</tip>
		<icon1>0</icon1>
			<instruction>Set FORMAT=!folder</instruction>
		</function>
	</button>
		<guid>{D7FAA54F-F317-4A4A-B393-777F38667578}</guid>
		<label>Folder &amp;Options...</label>
		<tip>Edit the appearance and settings of the current folder</tip>
		<icon1>86</icon1>
			<instruction>Properties FOLDEROPTIONS</instruction>
		</function>
	</button>
</button>
To get the above button to your Opus configuration:
  1. Copy the button code above to your clipboard.
  2. Right-click any Opus toolbar and select Customize.
  3. Right-click on the desired toolbar/menu to add the button to, and select Paste.
I've added some things to the button I posted above, like: Sort Order, Numeric Sort, Format Lock, Autosize Columns, Check Box Mode.
The intent is to give the user (and me) a single place to look for all commands related to Folder Options and Folder Formats. In this version of the button, I have turned off all images. I think the menu looks cleaner this way (and it takes up less space). The images are still present in the buttons, they are just not displayed. You can easily turn the images back on if you like.
<button display="label" effect="saturate" label_pos="right" type="menu_button">
	<guid>{DD104235-7BB5-4FF0-B045-91652583825A}</guid>
	<tip>Edit Folder Formats. Menu contains list of Favorite and Content Type Formats and other Folder Options related commands.</tip>
	<icon1>119</icon1>
	</function>
	<button display="label" effect="saturate" separate="yes">
		<guid>{D41D1C31-48AD-4653-BD01-65AD259A1CD4}</guid>
		<tip>Edit appearance and settings of current folder. Changes are lost upon navigating to a different folder, unless saved to a Format.</tip>
		<icon1>0</icon1>
		</function>
	</button>
	<button display="label" effect="saturate">
		<guid>{93E83330-D8CB-40A2-82C5-6751CCE79231}</guid>
		<tip>Shows a list of your Favorite Folder Formats</tip>
		<icon1>86</icon1>
		</function>
	</button>
		<guid>{574F417D-0699-4C4E-A150-1AD484872BD8}</guid>
		<tip>Reset Folder Options to those saved in the Format for the listed folder (if any).</tip>
		<icon1>0</icon1>
		</function>
	</button>
	<button display="label" effect="saturate" type="menu">
		<guid>{687C89FE-D177-42FC-A4D1-A7D408535CB5}</guid>
		<label>&amp;Sort By...</label>
			<guid>{BF720579-699C-4CE9-913C-6D0455E554C6}</guid>
			<label>Sortable Columns</label>
			<tip>Displays a list of the current columns allowing you to change the sort order</tip>
			<icon1>42</icon1>
				<instruction>Set SORTBY=sortlist</instruction>
			</function>
		</button>
			<guid>{049FB473-BD67-4B39-B5ED-C9B7188E4FA5}</guid>
			<label>Numeric Sorting</label>
			<tip>Toggles Numeric order filename sorting ON or OFF.</tip>
			<icon1>0</icon1>
				<instruction>Set SORTNUMERIC=Toggle </instruction>
			</function>
		</button>
			<guid>{0B7D27E5-D6F9-4538-BA2D-5604FC96F1C9}</guid>
			<label>Word Sorting</label>
			<tip>Toggles Word Sorting (special handling for hyphens, etc) ON or OFF.</tip>
			<icon1>0</icon1>
			</function>
		</button>
	</button>
		<guid>{D1E32677-E672-4DAA-BC01-383760797E72}</guid>
		<label>Format &amp;Lock</label>
		<tip>Locks or unlocks the Folder Options currently in use in the active Lister.</tip>
		<icon1>208</icon1>
			<instruction>Set FORMATLOCK=Toggle</instruction>
		</function>
	</button>
		<guid>{EA51E8FE-78D3-4BDA-9022-96FF74000D9A}</guid>
		<label>Autosize Columns</label>
		<tip>Autosize all Lister column widths (Details/Power mode only).</tip>
		<icon1>42</icon1>
			<instruction>Set AUTOSIZECOLUMNS</instruction>
		</function>
	</button>
		<guid>{3971BB68-0ADB-40CD-977B-000033F7274B}</guid>
		<label>Chec&amp;k-Box Mode</label>
		<tip>Toggle Check-Box Mode on or off in the active Lister.</tip>
		<icon1>206</icon1>
			<instruction>Set CHECKBOXMODE=Toggle</instruction>
		</function>
	</button>
</button>
