RE: HOW TO: Refer to programs on the same drive
Hi guys,
Regarding this post: [url]HOW TO: Refer to programs on the same drive as portable Opus]
I have set up alias commands to launch application on my portable Opus (see code below) which works fine. To set the icon, I would normally browse to the mplayerc.exe file and select one of the icons from within the exe. This doesn't seem to work with Alias commands, even if I edit the path after selecting the icon.
{alias|home}..\Utilities\mplayerc.exe
Is it possible to set a relative path to the icon rather other than using a drive letter?
Regards
Blueroly
Use this instead:
/home\..\Utilities\mplayerc.exe
Thanks Leo, works a treat.
