I think we can do this with the Ini-File. You'll get it with the next release, for sure.
Any more requests? Don't be shy
This and CSV are great plugins. Thanks very much for all of the work!
I think it's time to work on stability. I am getting problems with the autosave now . If I close an unsaved RTF document by closing the viewer pane, then try to edit once again I get an error "Code: 1400. Invalid Window Handle".
If I edit an RTF file in the viewer pane then I select a JPG file, it is not automatically saving the RTF. If I switch between RTF files it does save properly.
Make sure you are handling every error code and you are properly managing every resource you allocate.
I know, how to do my work
Ever seen a bugfree application?
The best of it is: I am able to reproduce it.
Fixing the second (switching between rtf and another filetype) will be hard. I have to think about it a while.
Please stand by.
Unicode filename support and 64 bit.
Regards, Norbert
This is a Delphi plugin so that may be difficult for Dinkelhopper to do for now. 64-bit at least; I don't know what the state of Unicode support is like.
CodeGear, who now own Delphi and most of what was Borland's development tools, have 64-bit support on the 2009 roadmap according to Wikipedia (though the roadmap article they cite does not seem to be online anymore).
I've been thinking about trying to write a generic 64-bit proxy for 32-bit plugins, like I wrote to allow 32-bit ActiveX controls (e.g. Adobe Reader and Adobe Flash) to work within the viewer of 64-bit Opus. It should be possible... 101 other things to do as always, though.
New Release post #1
(Bugfix and one new feature)
@Ross
I hope, we're stable now
Update: A workaround for this problem is included in Directory Opus 9.1.1.8 which just came out.
Please see Heads-up: dopus_fileinfo crashes and solution if you're using this plugin and have found Opus crashes sometimes.
Hopefully it'll be easy to fix but I figure the mysterious crash may be causing problems for some people so it's worth giving everyone a heads-up on how to avoid it for now.
Very good plugin, it even can edit. Thank you!
A workaround for the dopus_fileinfo crashes has been included in Opus 9.1.1.8. If you use this plugin then you should update Opus to avoid the crashes.
Is there a way that a hotkey can be assigned to switch the keyboard entry focus back and forth between the lister and the ViewPane editor? I know of the command "Set VIEWPANE=Toggle". But this only toggles display of the viewer pane and does not shift the focus. Also - I don't think Dopus hotkeys work when inside of the RTFViewer?
My goal is to be able to move between editing different files without any use of the mouse.
You could just use the tab key?
Opus hotkey assignments (that are not system-wide) will not work when any of the following have the system focus:
You can create a workaround to set focus from the Internal Viewer back to the Source file display by doing the following:
Go LASTACTIVELISTER Set FOCUS=Source
Thanks kenalcock. That solved half the problem to go from ViewerPane --> Lister. (but not vice-versa).
I found this solution to go both ways with AutoHotKey:
#IfWinActive, ahk_class dopus.lister F1::ControlFocus, dopus.filedisplay1, ahk_class dopus.lister F2::ControlFocus, TRichEditHack1, ahk_class dopus.lister #IfWinActive
When your are in a Lister with the Internal Viewer open, you can just Tab into the Viewer pane.
Had to reinstall Windows - Win XPSP3 on an HP dualcore Pavilion - and everything is working in DOpus except RTF viewer:( - it shows 'loading' for a nanosecond then just a blank pane. The debug.txt option doesn't work either; I cut and pasted the filename from the readme, honest. If I disable it I see raw RTF files. What's gone wrong? (deleted the plugins, redownloaded, etc.)
Hi,
Is it really \GPSoftware\Directory Opus\Viewers\dopus_viewer_debugfile.txt?
Can you reproduce this issue with every RichText-File?
Hi DH
Yes, it's the same for any RTF, however generated - all other file formats (vid/aud/txt/gfx) work. I haven't reinstalled Office yet...? Also haven't done a scorched earth reinstall yet.
Thanks
SOLVED! - Installed Office 2003 and it works!
