i meant 140 x14 = 1960
where can i find this option? In "Zip Files" I have "Activeate Opus Zip..." unchecked and everything is greyed.
Listers / Folder Tree
found it -- yes, it is unchecked.
Ok, I think I know what is going on. It seems like Microsoft have changed the way network enumeration works in Vista. We'll have a new version out soon which will hopefully improve this for you.
Awesome, looking forward to it, thanks!
9.0.0.4 should have improved this.
It is indeed very much improved! Thank you for fixing this.
Its much faster now that is does not spider each folder but just shows a plus next to each one. If I then click on the plus next to a folder that itself does not have any subfolders, the plus disappears as expected.
However, one minor annoyance is that if i instead click on an actual folder (not the plus) in the folder tree, that folder's contents are shown in the right-hand pane, but the plus does not disappear as it should (because it is now known that the folder does not contain subfolders). Can this also be fixed? Thank you!
This will be fixed in 9.0.0.6. Thanks for the feedback!
