Directory Opus 11.15.2 (beta)
Directory Opus 11.15.2 (beta) is now available for all Opus 11 users.
This is a preliminary, beta release. Translations may not be fully up-to-date and some English text may appear in non-English versions.
Download:
Changes:
  • Added the Set TREELOCK command which lets the folder tree lock be used even if the tree header is turned off.
  • Fixed crash under Windows 10 when double-clicking on an Acronis TrueImage .tib file.
  • The "Current sort field" background color setting was ignored when the file display was grouped.
  • Fixed overriding of certain system Windows+ hotkeys in Windows 10.
  • TrueImage context menu extensions are no longer blocked by default as they seem to be better behaved these days.
