New Folder Drop Down Button
Here is a new folder button with a drop down multi-option function which I quite like. :smiley:
The .dcf file and XML below are both the same. Use whichever is most convenient. See How to add buttons from this forum to your toolbars for what to do.
New.dcf (3.1 KB)
<?xml version="1.0"?>
<button backcol="none" display="icon" hotkey="ctrl+N" icon_size="large" separate="yes" textcol="none" type="menu_button">
	<label>New</label>
	<tip>Create a new folder</tip>
	<icon1>#Default XL:newlibrary</icon1>
	<function type="normal">
		<instruction>CreateFolder</instruction>
	</function>
	<button backcol="none" display="both" label_pos="right" textcol="none">
		<label>Ne&amp;w Folder\tCtrl+N</label>
		<icon1>#makedir</icon1>
		</function>
	</button>
		<label>Move into new folder</label>
			<instruction>Copy MOVE HERE CREATEFOLDER</instruction>
		</function>
	</button>
	<button backcol="none" display="both" hotkey="ctrl+H" label_pos="right" textcol="none">
		<label>New &amp;Archive...\tCtrl+H</label>
		<tip>Create a new compressed archive</tip>
		<icon1>#newzipfile</icon1>
			<instruction>CreateFolder ARCHIVE</instruction>
		</function>
	</button>
	<button backcol="none" display="both" hotkey="ctrl+O" label_pos="right" separate="yes" textcol="none">
		<label>New &amp;Text Document\tCtrl+O</label>
		<tip>Create a new, empty text document</tip>
		<icon1>#newtextfile</icon1>
			<instruction>FileType NEW=.txt</instruction>
		</function>
	</button>
	<button backcol="none" display="both" label_pos="right" separate="yes" textcol="none">
		<label>&amp;New</label>
		<tip>Create a new file or folder</tip>
		<icon1>#newfile</icon1>
			<instruction>FileType NEWMENU</instruction>
		</function>
	</button>
		<label>Move New Folder to Inactive Lister</label>
		<icon1>#DOpus9:dualdisplay</icon1>
			<instruction>Copy MOVE CREATEFOLDER</instruction>
		</function>
	</button>
	<button backcol="none" display="both" icon_size="large" textcol="none">
		<label>Copy and Move to New Folder</label>
		<tip>Copy Create New folders to the destination Lister</tip>
		<icon1>#move</icon1>
			<instruction>Copy CreateFolder COPYDESC=yes </instruction>
		</function>
	</button>
		<label>N&amp;ew Dated Folder</label>
		<tip>Create a new folder and automatically name it using the current date and time</tip>
			<instruction>CreateFolder NAME=&quot;{date|yyyy-MM-dd} {time|HH-mm-ss}&quot;</instruction>
		</function>
	</button>
		<label>&amp;Move into Dated Folder</label>
		<tip>Move the selected items into a new folder which is automatically named using the current date and time</tip>
			<instruction>Copy MOVE HERE CREATEFOLDER=&quot;{date|yyyy-MM-dd} {time|HH-mm-ss}&quot;</instruction>
		</function>
	</button>
</button>
