Using Hidden Video Indexes
Hello,
I'm still hoping to get some help creating a custom column for this to be complete but I thought I would post all my buttons.
Leo helped me out and created a column script that will indicate if an index is missing or not :thumbsup: Thank you, good sir!
What these buttons allow you to do:
  • Index selected video(s)
  • Index all videos
  • Select all indexes
  • Hide all indexes*
  • View hidden indexes
  • Play video from viewing index file
  • Play video from viewing index file and close Standalone Image Viewer
  • Select the corresponding video file from the currently viewed index
Demo
Requirements:
  • Dopus 12 (for the custom Standalone Image Viewer buttons)
  • Some kind of video thumbnail indexer (I'll be using Video Thumbnail Maker and my buttons will reflect that. Adjust for your needs. NOTE: Using Video Thumbnail Maker, I found I needed to use the full path to the saved profile in order to work correctly)
Buttons for when you right-click on a video
Settings > File Types > File Type Groups > Movies (Context Menu)
View Thumbnail
@nofilenamequoting
Show "{filepath$}.jpg" AUTOFILELIST
Index Videos... (Selected)(silent)
@runmode:hide
"/dopusdata\Scripts\Video Thumbnails Maker\VideoThumbnailsMaker.exe" "C:\Users\USERNAME\AppData\Roaming\GPSoftware\Directory Opus\Scripts\Video Thumbnails Maker\Options\your_saved_preset.vtm" {allfile$} /silent
Buttons for when you right-click a lister background
Settings > Customize Toolbars > Context Menus > Lister Context
Index All Videos (silent)
Select ALLFILES="grp:movies"
@runmode:hide
Hide All Indexes
Select NONE
Select ALLFILES="grp:Movies.jpg"
SetAttr ATTR h
Select All Indexes
Select NONE
Buttons for the Standalone Image Viewer (Dopus 12 required)
Play
adjust the path to your video player
"C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" {filepath$|noext}
Play & Close
Select DESELECTNOMATCH SETFOCUS EXACT PATTERN={allfile|noext}
Show VIEWERCMD=close
Select & Close
I started using VTM this week. It is a very nice program.
I made a script button to open the preview/index of a selected video file. It is a bit more complex than your "View Thumbnail" button. My script checks if there is a VTX file and opens it by default, otherwise it checks if there is a JPG file and opens it.
If you are interested, here is the Javascript code:
// Generic Name: View Preview
// Type: Button
// Function: open file with preview thumbnails if it exist for the first selected movie file.
// License: CC0 Public Domain
// Creator: https://andersonnnunes.org/
// ------------------------------- Button Preferences
@disablenosel:files
// ------------------------------- Event
function OnClick(clickData)
	// Name of file type group for movies.
	// If you defined a personalized file type group for your movies, type it here.
	var localizedMovieGroupTypeName = "Movies";
	// Determine verbosity level.
	// 1 - Print informative log.
	// 0 - Print nothing.
	var verbose = 0;
	// ------------------------------- Main
	DOpus.ClearOutput();
	// Check that there are files selected.
	if (clickData.func.sourcetab.selected_files.count == 0)
		print("No files are selected.");
	else
		// Adjust command behavior.
		cmd.deselect = false;
		cmd.SetQualifiers("none");
		cmd.ClearFiles;
		// Filter selected files to consider only movie files.
		for (var eSel = new Enumerator(clickData.func.sourcetab.selected_files); !eSel.atEnd(); eSel.moveNext())
			var selectedItem = eSel.item();
			for(var i=0; i<selectedItem.groups.length; i++){
				if (selectedItem.groups(i).display_name == localizedMovieGroupTypeName)
					cmd.AddFile(selectedItem);
		// For each movie file, define what to do.
		for (var iSel = new Enumerator(cmd.files); !iSel.atEnd(); iSel.moveNext())
			// Define paths.
			var cItem = iSel.item()
			var resPath = String(cItem.realpath);
			var extension = String(cItem.ext_m);
			var formats = new Array();
			var formatA = resPath + ".vtx";
			formats.push(formatA);
			var formatB = resPath.replace(extension, ".vtx");
			formats.push(formatB);
			var formatC = resPath.replace(extension, ".jpg");
			formats.push(formatC);
			var formatD = resPath + ".jpg";
			formats.push(formatD);
			// Find files.
			for (var i = 0; i < formats.length; i++)
				if (DOpus.FSUtil.Exists(formats[i]))
					if (i <= 1) {
						var openPreviewCmdLine = "ContextMenu VERB=Open FILE=" + "\"" + formats[i] + "\"";
					} else {
						var openPreviewCmdLine = "Show AUTOFILELIST " + "\"" + formats[i] + "\"";
					cmd.AddLine(openPreviewCmdLine);
					// Execute commands.
					cmd.Run;
					return;
	// Print only if requested.
	function print(text){
		if (verbose) {
			DOpus.Output(text);
When I upgraded from 12.6 to 12.7, I lost the use of my Standalone Viewer button. The viewer closes (2nd line) but no video file is selected.
Example file names:
  • video.mp4
Running ...{allfile|noext} while viewing video.mp4.jpg in Standalone Viewer, the code would remove the .jpg portion and select my video.mp4 file. Now, nothing gets selected.
Any thoughts on a fix?
Thanks!
I guess adding quatation marks around the code seemed to help.
..."{allfile|noext}"
Not sure how it all worked before, but it's working now.
