I would like to eliminate, on a few buttons, the vertical line that appears between an icon and label.
Bob
Bob
In Customize mode, just uncheck the highlighted option to get rid of the separator | vertical bar.
Regards, AB
Begin a Group is horizontal line between the buttons. I'm talking about the vertical line between the icon and label, text. That would encompass only a single button.
But thanks for taking the time.
Bob
Begin a Group is a vertical line on a horizontal toolbar. Here's another toolbar example with a "Begin a Group" vertical bar highlighted. Is that what you are looking to eliminate?
Regards, AB
I understand I could not do the line removal when I have 2 icons in play, as shown in above image. But at times, in edit, I have "Show Images" not selected. I expected the vertical line that separates the icons from the label not to appear. If I have several buttons, together, and no icons are used, I'm hopping that the line can be removed.
Sorry for not gives proper info on my original topic.
Bob
That is coming from the Windows visual style.
If you change Opus to drawing Office 2003 style menus you can remove it.
That might open a kettle of worms for me. I guess the line is not so much a problem after all.
Bob
