I'm using Windows 10 x64, and Directory Opus 12 as my file manager. It seems that the Copy Handler 1.44 context menu options are not available in DO. They are available in Windows 10 File Explorer. I'm attaching screenshots of both, as well as of ShellExView.
It looks like their shell extension is doing something slightly non-standard, but we should be able to make a change to allow it to work in the next update.
Thank you! I'm looking forward to the next update.
