Directory Opus version 9.5.2.0 – January 7th 2010
A free update for all Directory Opus 9 users is now available:
GPSoftware:
http://www.gpsoft.com.au
Direct Downloads:
Directory Opus 9.5.2.0 x86 (32 bit)
Directory Opus 9.5.2.0 x64 (64 bit)
Note for non-English users: The initial release was lacking translations but they have been added now.
Bugs fixed / minor changes:
- Fixed a problem introduced in the previous version that could cause a crash when the content type system was activated.
- Improved file date comparison in synchronize (particularly with the Ignore seconds option enabled)
- Improved support for display of 256x256 .ICO files
- Single locked tabs are now respected in the Default Lister or layouts (previously the lock state would be lost unless multiple tabs were configured)
- Numeric sorting rules are now applied to custom fields so fields like the Tortoise SVN Revision field will sort correctly
- Fixed scrollbar calculation problem in List mode that could result in weird behaviour depending on the size of the Lister
- Fixed problem with {allfile} command sequence when filename contains multiple periods
- Fixed support for PowerArchiver drag&drop menu
- Fix for duplicate entries appearing in the Open With menu in some situations
- Fix for buffer overflow in Raw plugin's config dialog
- Fixed problem that could cause slow copy speeds to removable disks
- Added support for additional file extensions to the CD jewel case thumbnail rendering (added .oga, .fla, .wv, .m4a, .m4p, .ape and .mpc)
