DOpus Resource Centre Forum Index DOpus Resource Centre
User-run support community for GPSoftware's Directory Opus
 HelpHelp   SearchSearch   RegisterRegister
    Log inLog in
Directory Opus, the Explorer replacement and File Management solution for Windows
Encode/Transcode selected WAV/MP3 files to MP3 using LAME
Post new topic   Reply to topic    DOpus Resource Centre Forum Index -> Buttons & Toolbars
View previous topic :: View next topic
Author Message
BenjaminW
anchor | Posted: Sat Jan 06, 2007 7:16 am    Post subject: Encode/Transcode selected WAV/MP3 files to MP3 using LAME Reply with quote
Use this button definition to easily encode/transcode wave or mp3 files to mp3 using LAME encoder (free). Please change the path to lame.exe according to your installation. Hitting the button will encode all selected files to the destination folder.
<?xml version="1.0"?>
<button display="both" effect="gray">
   <guid>{9CE8D1E0-DEB3-4709-9212-D79474B8754B}</guid>
   <label>Encode MP3 (to destination) - Quality: VBR 4</label>
   <icon1>12</icon1>
   <function type="batch">
      <instruction>"C:\__CHANGEME__\lame.exe" -V 4 --vbr-new {filepath$} {destpath$}{file$|ext=mp3}</instruction>
      <instruction>pause</instruction>
   </function>
</button>
Hope this is interesting for you. Please give feedback.
LAME can be downloaded from several sources (ask google!). Official site: http://lame.sourceforge.net/index.php
Back to top
View user's profile Send private message
BenjaminW
anchor | Posted: Thu Jan 11, 2007 9:01 am    Post subject: Vice versa Reply with quote
For decoding a MP3 File to WAVE you can use LAME, too:
   <label>MP3 Dekodieren</label>
   <icon1>12</icon1>
      <instruction>"C:\__CHANGEME__\lame.exe" --decode {filepath$} {destpath$}{file$|ext=wav}</instruction>
   </function>
</button>
See the documentation of LAME for other command line options (quality, ID3-Tags, etc.).
Back to top
BenjaminW
anchor | Posted: Sun Jul 08, 2007 9:01 pm    Post subject: Reply with quote
If you want to transcode a MP3 file to a lower bitrate (i.e. you have a 320 CBR file and you want it to be 128KBit VBR) you can use the first command, too. But LAME will not write the ID3 Tag in the destination file for whatever reasons.
Here's a little extension to the command. Just paste this line after the LAME command:
"C:\_PATH_TO_id3cp_\id3cp.exe" {filepath$} {destpath$}{file$|ext=mp3}
It will just copy the source file's ID3 Tags to the new encoded file! Smile
The needed program for this is attached to this thread.
Have fun!
 Filename:  id3cp.zip
Download
 Filesize:  268.39 KB
 Downloaded:  395 Time(s)
Back to top
leo
Admin
anchor | Posted: Thu Jul 12, 2007 12:35 am    Post subject: Reply with quote
I have split the discussion that was in this thread, about variables and DOS windows, into a separate thread here:
http://resource.dopus.com/viewtopic.php?t=5785
Once the discussion results in a finished button please post it here, but let's keep ongoing discussion out of this area so people can easily find buttons, rather than talk about buttons. Smile
_________________
My Opus Intro & Plugins | FAQs | Opus 9.5.2.0 (07/Jan/2010) | Opus News Blog/RSS | Contact GPSoftware
Back to top
View user's profile Send private message Visit poster's website
Sasa
anchor | Posted: Thu Jul 12, 2007 8:26 am    Post subject: Reply with quote
Final button:
This will encode files from source to destination. The selected encoding quality will be used for all files!
<button display="both" label_pos="right" separate="yes">
   <label>Encode MP3</label>
   <icon1>12</icon1>
      <instruction>@set var = {dlgchoose|Select encoding quality:|VBR ~165 kbps (4 - medium)=-V 4 --vbr-new+VBR ~190 kbps (2 - standard)=-V 2 --vbr-new+VBR ~240 kbps (0 - extreme) =-V 0 --vbr-new+CBR 128 kbps=-b 128+CBR 160 kbps=-b 160+CBR 192 kbps=-b 192+CBR 320 kbps=-b 320}</instruction>
      <instruction>____ENTER_PATH___\lame.exe &quot;{$var}&quot; {filepath$} {destpath$}{file$|ext=mp3}</instruction>
      <instruction>Pause</instruction>
   </function>
</button>
Back to top
BenjaminW
anchor | Posted: Thu Jul 26, 2007 12:43 am    Post subject: Reply with quote
Very neat!
That is cleaning up my MP3 encoding menu a lot Wink
Back to top
Devilder
anchor | Posted: Sun Jul 29, 2007 7:12 am    Post subject: Reply with quote
I like this feature a lot, but just some questions....
Encoding MP3 to WAV will not getter better quality.
Reencoding an MP3 to MP3 using Lame would IIRC lower the quality even more.
Confused
Back to top
Sasa
anchor | Posted: Sun Jul 29, 2007 10:37 am    Post subject: Reply with quote
Confused
1. Decoding MP3 back to WAV will NOT bring you back original quality (MP3 is compressed audio and not lossless - you will always get the quality of the MP3 when decoding)
2. You shouldn't re-encode a MP3 (this means loosing more quality as the source-mp3). Except you want to save space on a MP3-Player for example (I always re-encode higher quality MP3 to VBR 160 (LAME Preset 4) for my player).
Also LAME will bring you best results with VBR Preset 2 (~190kbps). At CBR 320kbps you won't hear a difference between MP3 and WAV.
Back to top
Display posts from previous:
Post new topic   Reply to topic    DOpus Resource Centre Forum Index -> Buttons & Toolbars All times are GMT - 8 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Trademarks and Copyrights: Windows and Explorer are trademarks of Microsoft Corporation; Amiga and Workbench are trademarks of Amiga Inc;
Directory Opus, Opus, OpusPC, PCOpus, DOpus, DirOpus,Opus File Manager and Opus for Windows are trademarks of GPSoftware or associated companies.
Powered by phpBB © 2001, 2005 phpBB Group
