The plugin allows you to view Maya .IFF files in the Opus viewer pane.
(Note that Maya IFF files are different to the Amiga IFF ILBM format which Opus handles internally. The plugin will not break IFF ILBM support and once installed you can view both types of IFF files without doing anything special.)
Go to the plugin's webpage for more information:
http://www.pretentiousname.com/maya_iff/index.html
