A free update for all Directory Opus 9 users is now available for download from GP Software.
Bugs fixed / minor changes:
- Fixed crash introduced in 9.1.1.1 when using the Copy ZIP SENDMAIL function (and some other functions). Sorry about that!
- Fixed cosmetic problem with long labels overwriting other columns in List mode when auto-size columns turned off.
- The Power mode drag-and-drop configuration option for ‘immediate action’ now works correctly.
- Updated ActiveX Plugin to Version 3.1.0.6
- Improved handling/restoration of input focus when you change files while inline renaming and the ActiveX viewer is open.
- Increased the amount of time that the plugin waits for focus to be taken from 5 seconds to 60 seconds.
