Directory Opus version 9.1.1.6 - December 17th 2008
A free update for all Directory Opus 9 users is now available for download from GP Software.
Bugs fixed / minor changes:
- Fixed problem multiple-line functions that modify the file selection (e.g. by calling the Select command) – it was possible in some cases for the first file to be processed twice.
- The Compatibility Files feature now supports the Program Files (x86) folder in Vista/XP x64.
- The Go SWITCHPATH command now supports aliases. The SWITCHPATH argument now supports more than one alternative path, to enable cycling through as many paths as desired. E.g. Go C:\ SWITCHPATH D:\ E:\ F:\ would cycle through the C, D, E and F drives.
- Shift+F10 now correctly brings up the context menu in the Folder Tree
- Fixed a problem where some images converted from TIFF to JPG would not be recognised in Photoshop
- Fixed several problems with Drag & Drop in terms of the feedback cursor and behaviour on drop – the cursor you see should now correctly indicate the drop action in all cases.
- Drag & Drop from SmartFTP to Opus now works.
- Drag & Drop in List Mode now lets you scroll the list to the left or right by hovering at the edge of the window.
- Fixed a problem with the Viewer Plugin SDK where paletted images provided to Opus did not correctly respect their transparency settings.
- The Keep On Top function in the Lister window menu did not work correctly – fixed.
- In thumbnails mode, selecting a file by pressing the space bar now updates the viewer pane correctly.
- The Copy EXTRACT HERE command now works correctly on folders as well as archives.
- Fixed a problem whereby input focus could be lost after deleting a folder if there was a text file viewed in the viewer pane.
- The Copy MOVEWHENSAME function did not work correctly between sub-directories under junction points.
- The command sequence {sourcepath|..|nopath} now correctly gives the name of the parent folder rather than the current folder.
- External commands run through the FAYT field (by typing >) now have their current directory set correctly.
- Ctrl+Home/End now works correctly in Power/Details mode.
- Fixed a problem with File Descriptions when used with files in a junction folder on a network drive.
- The Flat View setting in Lister Styles now works correctly.
- Fixed a problem where activating a style could create duplicate folder tabs in some cases.
- The Author and Keywords columns now work correctly with recent Office documents.
- Icon Sets stored in /dopusglobaldata are now correctly exported to USB.
- Icon mode range-selection points are now correctly updated when files are added or removed from the list.
- Fixed a crash that could occur if you dragged the Control Panel icon to a File Collection.
- If a folder is open in a Lister and that folder is moved, the Lister now automatically updates to show the new location.
- Button icon definitions now support environment variables.
- ActiveX plugin: Fix for SWF (etc.) files not displaying if viewed directly from UNC paths
- Added support for Photoshop (PSD) CMYK and 8-bit indexed images
- Fixed several minor cosmetic bugs.
