Font-Viewer (ttf, otf)
Viewer and VFS (Virtual File System) plugins.
Postby Dinkelhopper » 19 Jan 2009, 08:07
This ViewerPlugin lets you preview FontFiles (TrueType (ttf) and OpenType (otf)) within the Dopus-ViewerPane.
It works with installed and non-installed FontFiles!
Configure the included Ini-File to change the text and the fontsizes the text will be displayed.
The lower RichEdit is not read only so you are able to type your own text (temporarily)
It should work under 32bit XP and Vista.
Feedback is welcome :)
Current Version: 1.1.1 (11.02.09)
Please take a look at these files:
readme.txt => further information and usage
history.txt => changelist
ATTENTION:
Referring to this post, please use my PlugIns only with DOpus 9.1.1.8 or higher! I'll limit the usage to this version in a further release. Thanks.
FontViewer.zip
(256.64 KB) Downloaded 2079 times
Dinkelhopper
Postby Ben Hill » 20 Jan 2009, 07:36
Thanks very much. It works very well for me, fast and smooth. I've been eager to have this extra capability in my file manager.
I have one question for you. Is it possible to have the viewer give the name of the font? That would be helpful to me. Often I don't recognize the *.ttf or *.otf name.
Ben Hill
Postby Dinkelhopper » 20 Jan 2009, 08:03
Ben Hill wrote:Is it possible to have the viewer give the name of the font?
Take a look at the StatusBar ;)
Dinkelhopper
Postby AlbatorV » 20 Jan 2009, 08:29
Excellent, thanks...
User avatar
AlbatorV
BBT
OS: Windows XP 32-bit
Opus: Illuminati
Postby Ben Hill » 20 Jan 2009, 10:25
Thanks. I should have seen that. Looks very good.
Ben Hill
Postby Christiaan » 20 Jan 2009, 12:13
Great to have a Viewer Plugin to preview FontFiles for WinXP! :D
The plugin only works with the WINDOWS\Fonts directory if you choose to have DOpus display the WINDOWS\Fonts folder as a real folder: :wink:
Untitled - 31.png (20.81 KB) Viewed 6700 times
User avatar
Christiaan
OS: Windows Vista 32-bit
Opus: Directory Opus 9.x
Postby Dinkelhopper » 20 Jan 2009, 12:36
Christiaan wrote:The plugin only works with the WINDOWS\Fonts directory if you choose to have DOpus display the WINDOWS\Fonts folder as a real folder: :wink:
oops, sorry - I forget to mention this :(
I think this will be considered to every plugin.
Dinkelhopper
Postby fred » 20 Jan 2009, 13:31
Great work! Thank you
However, I can't get FontViewer.ini to work. I try to save the file in ANSI, UTF8 or Unicode with no sucess.
I have the last version to date: 19/01/2009 16:55:38
Config: XP SP3, DOPUS 9.1.1.6
- Win XP PRO SP3
- Directory Opus 9.5.4.0 x86
- Firefox 3.6.3 (THE browser)
User avatar
fred
Postby leo » 20 Jan 2009, 15:38
There is a Font Name column which you can turn on in Opus to tell you the name of each font.
Also, this plugin seems to work fine with the Fonts folder shown as virtual, although it didn't initially for some reason. (I enabled the unrelated MultiView plugin, to test if it would show something to prove to myself that plugins can see files in virtual folders and after doing that the FontViewer plugin worked fine for some reason, even if I then disabled MultiView.
Edit: Next to paragraphs crossed out. Turns out it works okay on Vista but there is indeed a problem on XP.
Dinkelhopper, it might be worth debugging the file paths you get when files in the virtual font folder are selected. Maybe they're in an unexpected format?
The Text viewer plugin has no problems showing files in virtual folders (as hex in this case) so it definitely should work for all plugins.
Good work, BTW. Nice to see some new plugins!
User avatar
leo
Admin
OS: Windows 7 64-bit
Opus: Illuminati
Postby trevorm » 20 Jan 2009, 15:51
Works the very best! Many thanks for this. Very useful!
trevorm
BBT
Postby Christiaan » 20 Jan 2009, 16:05
Also, this plugin seems to work fine with the Fonts folder shown as virtual (...)
When I enable the MultiView Plugin and/or the FontViewer Plugin (in WinXP) it also doesn't show anything with the Fonts folder shown as virtual:
(but it's not a big problem for me, because it works fine with the Fonts folder shown as real)
User avatar
Christiaan
Postby leo » 20 Jan 2009, 17:13
Just tried on XP and you're right. Must be something different with XP and Vista.
Since the text plugin also doesn't show anything Dinkelhopper is right in that it isn't the plugin's fault. I'll report that to GPSoft so they can take a look at it. For now, as Christiaan said, you can tell Opus to treat the Fonts folder as real to work around the problem on XP.
BTW, anyone using Vista should have a font viewer built in. (The Opus ActiveX plugin will use the Font preview handler which ships with Windows. That works with both 32-bit and 64-bit.) So the combination of this plugin and the ActiveX plugin means that everyone can now examine fonts in the viewer pane, one way or another, except for the small number of 64-bit users running Windows XP.
User avatar
leo
Admin
Opus: Illuminati
Postby Dinkelhopper » 20 Jan 2009, 21:05
leo wrote:I'll report that to GPSoft so they can take a look at it.
Thanks for your assistance.
Dinkelhopper
Postby Dinkelhopper » 20 Jan 2009, 23:21
fred wrote:However, I can't get FontViewer.ini to work. I try to save the file in ANSI, UTF8 or Unicode with no sucess.
Could you attach your FontViewer.ini, please?
Dinkelhopper
Postby Ben Hill » 21 Jan 2009, 07:21
My Fontview.ini is attached.
The Fontview.ini doesn't change text or font sizes from the default settings whether it is in the Viewers sub-folder or not.
Everything else works nicely.
FontViewer.zip
(219 Bytes) Downloaded 248 times
Ben Hill
Next
Return to Plugins
