9.0.0.8 - 2 new features not working on my system
Hello,
two of the new 9.0.0.8 features seem to refuse to work on my system (I'm using the corrected 9.0.0.8 version):
Pressing the up and down cursor keys has absolutely no effect.
When pressing Alt-Enter in the breadcrumbs bar, the properties of the selected folder or file are shown. This is a DOpus standard key combination, I didn't define it myself.
Am I doing something wrong, or are these some minor bugs?
Cheers,
Jan
I expect you're using LIST mode.
The arrow keys do nothing here in list mode too and the alt-enter opens the path AND the properties here. Both work fine in DETAILS mode.
I'm not sure if they're intended to work in LIST mode but might be worth your while making an official bug report.
That's correct, thanks for the hint.
Hm, pressing Alt-Enter in the breadcrumbs bar still just opens the properties window, even in details mode. Maybe I'm just too tired (it's 4:11 a.m. here) to get it to work; I'll try it again tomorrow. :wink:
I might consider that. :wink:
Cheers,
Jan
