A couple of questions
  1. when i try to copy a folder from an encrypted archive to my Nokia-phone using Dopus - it hangs :slight_smile:
  2. when i use "copy extract" to extract files from many archives - Dopus do it... but when the command has finished - Dopus still use much CPU!! What's this?
  3. Can i "copy as" items from net paths with {owner} information field?
You should report that to GPSoft.
Does it only happen with particular archives or file types (inside the archives) or destination folders? Can you give us some steps to try that would reproduce the problem?
At the moment only the Rename command can include things like {owner} in the filenames it produces so I think you'd have to rename the files and then copy them which isn't perfect.
