A sequential hotkey triggers a FAYT mode in some situations
Probably because of the FAYT quickkeys changes,since this didn't happen to me before.
Now if I use any FAYT mode, after the bar closes and I try to use a sequential hotkey right after, the last FAYT mode gets recalled, with its quickkey being typed into the FAYT field (if possible).
Am I missing something new I should disable or change so this doesn't happen?
Note 1: The sequential hotkey in question shares no keys with the FAYT quickkey.
Note 2: It happens with any FAYT mode, including the built-in ones. And I don't have any two-char quick key configured, FWIW.
Also report here...
Thanks, that's been fixed for the next beta.
