Acrobat Help File Settings
Each time I load the acrobat help, it seems to zoom to 75% size (!)
I would like to alter the default zoom to page width, but this feature sems to be disabled (presumably via the security options set at the author's end). Can this be changed?
(I am using Acrobat Pro 6)
