Similar to how you can activate a specific Find as you type mode with a single key, I'd like to activate the default Find mode with a single key without that key being typed into the FAYT bar
The reason for this is I'm using single keys for navigation (e.g., J↓ K↑), so then I lose the ability to search files starting with J and K
I'l like to assign another key (e.g., F) to activate the Find mode of FAYT without F actually appearing in the text field. But the options don't allow specifying a trigger for this, only for all the other non-Find modes
This unfortunatley doesn't work since it interferes with an explicit FAYT shortcut
If I bind s to Search and then use this custom f shortcut to activate FAYT, then I can't type a word with S in it
I think the proper solution is to add an explicit shortcut key to the FAYT list for the default command as well (there is a shortcut when None is selected as the default, but then I only want to override a couple of keys, wouldn't want to lose all the find activators)
