Activate Help
I must have turned off F1 function in Opus. I searched help but can't find it. But I did come across an interesting item on an email but. Can you lead me to the switch.
Sidebar: In many reviews I see Opus is hard to use, which is a bit of a crock. This analogy might seem a bit over-the-top but Opus is like studying for a doctorate. If you want to be good you have to study. And usually the review is done by someone that loads the program, for a couple of weeks, to give a review. Had I read an interview like this eight years ago I would have shortchanged my computer experience.
The command is just "Help" if you want to create a button for it. Or drag out the pre-made button from the Customize dialog. It's in the Help category.
Maybe it was in another program. If you highlighted a particular item, and hit F1 at the same time, it would bring up your help regarding the highlighted item.
