I have a button that runs MS Edge.
I might minimize Edge on my third screen.
If I press the Edge button in Directory Opus, I don't want another instance of Edge to start (on screen 1). I just want the current one to be activated.
Is this possible?
Is this possible?
That's up to Edge more than Opus. If it doesn't work that way by default, it may have command-line arguments to tell it to work differently, or there may be other ways to do it than running it directly. (For example, launching a URL would usually reuse the existing browser window, if it's the default browser.)
If Edge has a method for telling it to do what you want it to do, Opus can probably trigger it, but the actual method will depend on Edge.
