Is it possible to add another toolbar to each pane? I'd like one toolbar to show the current path and another where I can add buttons that would perform actions on that pane.
If needed, make a new toolbar via Settings > Customize Toolbars.
You can then tell Opus to open it above each file display via Settings > Preferences / File Displays / Border.
Editing it is the same as editing a normal toolbar.
Cool, thanks!
