When I right click on a folder, I get the
Open
Explore
Open in a new folder tab
etc.
I read the help on context menus, but I must be blind - as I don't see this menu listed.
I want to add a 'New Folder' command to this context menu.
thanks!
Open
Explore
etc.
thanks!
Goto Settings->File Types...->All folders->Context Menu
Add a New item set to Type Run an Opus function (Not supported in Explorer) that runs the command: Go NEWTAB
Whaaaaaat am I talking about?
Sorry... so now that I've actually READ your question, I guess you're saying you want a context menu item that creates a New Folder in the folder you've right clicked on?
Do all the same stuff as above - but instead of Go NEWTAB use a command like CreateFolder NOUPDATESETTINGS
