Add (move up, move down, move to beginning, and move to end) to context menus
Hi,
Many main menus or sub-menus sometimes user would like to arrange to particular preferences.
Like the menu in the image below, I would like to arrange it according to my preferences.
So is it possible to add an arrangement option to the right-click menu?
I do not mean this particular menu in the image but I mean in general.
Thanks
You can drag things in context menus to wherever you want them, in terms of what's shown in the screenshot.
In the more general case, for right-clicks on files and folders, the order can only be overridden by turning off Windows items on context menus (so nothing from outside of Opus is added to the menus automatically) and then manually adding the items you want in the order you want them. (Which is what I do, and not too much effort if you only want to see a handful of items. I then have a sub-menu that shows all the automatic items for when I need them.)
