Add to Named Archive puts ZIP in parent folder when using Expanded Folders
Hi,
I have noticed something confusing when using Expanded Folders in Directory Opus.
For example, I am in:
S:\Spel-Steam
and expand a subfolder directly in the file display. I can see and select the files inside that expanded subfolder without navigating into it.
If I select a file inside the expanded subfolder and use:
Directory Opus Archives → Add to ".zip"
the ZIP file is created in:
S:\Spel-Steam
instead of in the actual folder containing the selected source file.
If I first navigate into the subfolder itself and perform exactly the same operation, the ZIP is created in the expected location, next to the source file.
This seems a little inconsistent, since the documentation for Add to Named Archive says:
“The new archive will be located in the same folder as the source files.”
Is the behaviour with Expanded Folders intentional?
Ideally, I would expect Add to ".zip" to create the archive in the actual folder containing the selected file, regardless of whether I have navigated into that folder or am accessing the file through Expanded Folders.
I cannot remember this behaving this way in earlier versions of Directory Opus, although I may simply not have noticed it before.
Is there a setting which makes Add to Named Archive use the selected file's actual folder when working with Expanded Folders, or would this require a custom command/script?
Thanks.
