Adding desciption to Info Tool Tip
Hello team, this is the best software alive right now.
My query lies in how to add description showing in the info tool tip. I use too many books to read and I have set which book is specialized for which topic in the description so it is easy to open a specific book when reading that topic.
plus, I don't know how to add custom commands so, if the solution is to write a custom command in dopus, then please enlighten me with basic code stuff.
Thank you team.
This can be added via Settings > File Types.
You can change it for all files...
... or specifically for certain extensions, such as .pdf and .epub, or file type groups, e.g. Documents.
Thank you. Works perfectly :slightly_smiling_face:
