Why i can't use "alt+" hotkey in commands? it doesn't work!
It works fine here.
The hotkey may already be used by some other button/menu. Buttons/menus with & before letters in their labels (when you edit them; it'll turn into an underscore when not editing them) automatically create alt+ hotkeys. e.g. The F&avorites menu opens on alt+a.
i have no "alt+z" hotkey, but my sort command doesn't work! what's wrong? (when i push alt button i only see highlighting of menus first letter and nothing goes on) thus i must use only "win+z", but i really need "alt"!
Hotkeys defined by adding & in button labels do not appear in the Keys list.
That said, if you're using an English install then there isn't any alt+z button/menu by default, so unless you've created an item whose label contains "&z" it may not be what I thought it was...
If you assign some other hotkey (not involving alt) to the same command, does it work?
yes, of course! win+z works fine! any other key too!
Does Alt+K work for you as a hotkey?
(That one should also be free with the default English config & toolbars.)
Alt+K works fine! Can i free all Alt combinations?
There must be either some other menu/toolbar item with &z in its label, or a 3rd party tool which is swallowing the alt+z keystroke system-wide.
