Using a column script (JScript) to display aspect ratio and occasionally I get this error appearing
so I put in some code that I thought would stop it doing this
if ( isNaN(c.metadata.image.aspectratio) || (c.metadata.image.aspectratio == null) )
ar = 0;
else
ar = c.metadata.image.aspectratio;
but am still getting the occasional same error.
Is the above code wrong ?
here is the complete code
// Version 2.1
// Aspect column (as different from built in decimal Aspect Ratio column)
// Aspect ratios apply to image, display and print sizes
// Orientation (portrait, landscape) is used for aspect ratios that are not industry standard
// https://resource.dopus.com/t/column-for-showing-orientation-of-image-using-words/41889
// some useful sites
// https://en.wikipedia.org/wiki/Display_aspect_ratio
// https://en.wikipedia.org/wiki/Graphics_display_resolution#2560_%C3%97_1440_(QHD)
// https://en.wikipedia.org/wiki/Aspect_ratio_(image)
// https://papersizes.io/us/
// https://www.blake-envelopes.com/media/wysiwyg/downloads/ISO-paper-sizes.pdf
// The OnInit function is called by DO to initialize the script add-in
// https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Scripting/OnInit.htm
can put your columns into the main categories now,
Don't think it's fully documented yet,
but with script columns it's set via ScriptColumn.category,
which takes one of these string values:
"loc"
"date"
"size"
"std"
"dims"
"image"
"music"
"prog"
"doc"
"movie"
"sums"
"script"
"shell"
"other"
"eval"
function OnInit(w) {
w.name = 'Aspect'; // display name
w.group = 'Columns'; // group name shown in the scripts dialog
w.version = '2.1';
w.desc = 'Column to show orientation of image';
w.url = 'https://resource.dopus.com/t/column-for-showing-orientation-of-image-using-words/41889';
w.copyright = '(c)2022';
w.default_enable = true;
w.min_version = '12.28';
// Initialize OnAddColumns event by creating a new ScriptColumn object y and initialize it to add the column to DO
// https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Scripting/OnAddColumns.htm
function OnAddColumns(z) {
var y = z.AddColumn();
y.name = 'aspectzxy'; // internal keyword of the column.
y.label = '- Aspect'; // name for the column, displayed in the menus
y.header = '- Aspect -'; // name for the column header. If not set, the label value will be used
y.category = 'dims'; // undocumented. defines the category sub-menu as shown when right-clicking the column header. (see above)
y.justify = 'center';
y.type = 'wordsort';
y.autogroup = true;
y.autorefresh = true;
y.method = 'OnAspect';
// AddColumn.method function passed a ScriptColumnData object x
// https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Scripting/Item.htm
function OnAspect(x) {
var c = x.item;
if (c.metadata != 'image') return;
// else must be an image
// see https://en.wikipedia.org/wiki/Aspect_ratio_(image)
// ~cinemaatic, tv, monitor, wide monitor, ultra wide monitor, letter, A, B, postbox ????
var ar = 0;
ar = 0;
else
if ((ar > 0.94 && ar < 1.0) || (ar > 1.0 && ar < 1.22)) x.value = "Squarish";
else if (ar == 1.0) x.value = "Square";
else if (ar < 1.0) {
// PORTRAIT ORIENTATED ASPECT RATIOS
x.value = "Portrait";
if (ar > 0.79 && ar < 0.81) x.value = "4:5"; // old monitor
if (ar > 0.76 && ar < 0.78) x.value = "Letter (P)"; // US paper size - Letter, ANSI A,C,E
if (ar > 0.75 && ar < 0.77) x.value = "Government Letter (P)"; // US paper size - Government Letter
if (ar > 0.74 && ar < 0.76) x.value = "3:4"; // old TV, Arch A,C,E
if (ar > 0.70 && ar < 0.72) x.value = "A4 Portrait"; // A,B,C series, Arch E1
if (ar > 0.68 && ar < 0.70) x.value = "Arch E3 (P)"; // Arch E3
if (ar > 0.67 && ar < 0.69) x.value = "Arch E2 (P)"; // Arch E2
if (ar > 0.65 && ar < 0.67) x.value = "2:3"; // portable PC's, Arch B,D
if (ar > 0.64 && ar < 0.66) x.value = "Government Legal (P)"; // US paper size - Government Legal
if (ar > 0.63 && ar < 0.65) x.value = "Tabloid (P)"; // US paper size - Tabloid, Ledger, Half-Letter, ANSI B,D
if (ar > 0.61 && ar < 0.63) x.value = "10:16"; // computer monitor, US paper size Junior Legal
if (ar > 0.59 && ar < 0.61) x.value = "Legal (P)"; // US paper size - Legal
if (ar > 0.55 && ar < 0.57) x.value = "9:16"; // Widescreen
if (ar > 0.41 && ar < 0.43) x.value = "9:21"; // Ultrawide
if (ar > 0.27 && ar < 0.29) x.value = "9:32"; // Superwide
else {
// LANDSCAPE ORIENTATED ASPECT RATIOS
x.value = "Landscape";
if (ar > 1.24 && ar < 1.26) x.value = "5:4"; // old monitor
if (ar > 1.28 && ar < 1.30) x.value = "Letter (L)"; // US paper size - Letter, ANSI A,C,E
if (ar > 1.30 && ar < 1.32) x.value = "Government Letter (L)"; // US paper size - Government Letter
if (ar > 1.32 && ar < 1.34) x.value = "4:3"; // old TV, Arch A,C,E
if (ar > 1.39 && ar < 1.41) x.value = "Arch E1 (L)"; // Arch E1
if (ar > 1.40 && ar < 1.42) x.value = "A4 Landscape"; // A,B,C series
if (ar > 1.43 && ar < 1.45) x.value = "Arch E3 (L)"; // Arch E3
if (ar > 1.45 && ar < 1.47) x.value = "Arch E2 (L)"; // Arch E2
if (ar > 1.49 && ar < 1.51) x.value = "3:2"; // portable PC's, Arch B,D
if (ar > 1.51 && ar < 1.53) x.value = "Government Legal (L)"; // US paper size - Government Legal
if (ar > 1.53 && ar < 1.55) x.value = "Tabloid (L)"; // US paper size - Tabloid, Ledger, Half-Letter, ANSI B,D
if (ar > 1.59 && ar < 1.61) x.value = "16:10"; // computer monitor, US paper size Junior Legal
if (ar > 1.63 && ar < 1.65) x.value = "Legal (L)"; // US paper size - Legal
if (ar > 1.76 && ar < 1.78) x.value = "16:9"; // Widescreen
if (ar > 2.32 && ar < 2.34) x.value = "21:9"; // Ultrawide
if (ar > 3.54 && ar < 3.56) x.value = "32:9"; // Superwide
