Edit > Select Other > Checkboxes to Selection will do it as a one-off, but would need to be used again after checking/unchecking things.
Checkboxes in Opus aren't really the same as the ones in File Explorer (and predate File Explorer having them at all). But maybe we should add a mode which acts similarly, or an easier way to toggle-select without having to hold Ctrl or use the middle mouse button (for situations where there isn't one).
Would love it if you guys could add that as a feature later!
The setting is decent as a temporary solution. Can probably add it as a direct button to avoid going through those layers.
Love that theme, but the checkboxes are a little small and it's hard to get a grip on what's actually selected lol!
