Any way to popup a Listers Selection menu using System Wide Hotkey?
I'd like to assign a system-wide hotkey to bring up a menu so I can select a lister layout to open (like when you right-click on the system tray).
This is so I can bring up a Lister without using the mouse from whatever I'm using.
Is this possible? Even better if the context menu that comes up is editable.
You could probably do it using scripting, but there isn't a simple built-in way.
Defining some hotkeys for specific layouts is easy to do, on the other hand.
Thanks for the reply.
Is there any way to do a hotkey to activate the system tray context menu?
None that I know of.
What kind of scripting were you talking about when you mentioned it before? Any docs that I can check out?
See here:
OK, thanks.
