Append filename when extracting to destination lister
Hi,
this is my first post here and I have a question to ask, but first I want to thank GPSoft for such a wonderful program. Never have I used anything that in both customizability and functionality can compete with Directory Opus.
Now to my (very basic) question: How do I append the filename(s) of the archive(s) I want to extract to the destination lister?
"C:\Program Files\7-Zip\7zG.exe" x -o"{destpath}" {filepath}
so that destpath => destpath*, where * is/are the archivename(s)
greets,
Zetto
If your means was understood right by me and you want to extract selected 7z file/files to separated directories with the same name on destination, the following code will be your answer:
@filesonly @sync: "C:\Program Files\7-Zip\7zG.exe" x {o} -o{d}{o|noext}
Best Regards
wonderful, that was exactly what I wanted. thanks
