Maybe I've missed something obvious by rereading the docs and the forums, but for archives, I can't find the MOVE to archive? option found in the archivers themselves?
In other words: ADD files/folders to archive then (if success) DELETE the original files.
Is this intentional (I've only been using DO since version 12)?
You can make a button which combines the commands to add the selected files to an archive with the delete command to delete the selected files afterwards. Just find the specific archive command you want and add a line with Delete on the end of it. (Try it on some test files first, of course!)
Personally, I prefer to do them in two separate steps, but it's up to you.
When going inside an existing archive, you can also move things into it as you would move them into a normal folder.
