Assign a value to a variable using regular expressions
In a JScrip type script, having:
var name = item.name_stem;
How could I do to:
var title = first part of name;
var artist = second part of name;
The separator between the first and second part of the name would be a hyphen (-).
Example: 01. Billie Jean - Michael Jackson.mp3
I think the regular expressions should be these:
(^[0-9\.\s]*)(.*)(\s-\s)(.*) Select \2
(^[0-9\.\s]*)(.*)(\s-\s)(.*) Select \4
var title = name.replace(/(^[0-9\.\s]*)(.*)(\s-\s)(.*)/, "$2");
var artist = name.replace(/(^[0-9\.\s]*)(.*)(\s-\s)(.*)/, "$4");
Wow @Leo, that looks wonderful, thank you very much, I'll experiment!
One thing to keep in mind is that x.replace(...) only works when x is a string.
That's fine with item.name_stem but some methods return things like Path objects instead of strings.
If you run into trouble with those methods, an easy way to force the object to become a string is to add an empty string to it.
For example, item.path gives you a Path object, but item.path + "" will give you a string.
I understood @Leo, but it is working very well, thanks once again!
@Leo, let me ask you something else. How can I make a button only enabled when there are selected audio files?
Normally I use @disablenosel:type=*.(mp3|wma|ogg)but there are always files that are left out.
I'm asking you about something like: @disablenosel:type=metadata == "audio"
Thank you so much
Instead of *.(mp3|wma|ogg) try grp:Music. That will include all the extensions in the Music file type group.
Perfect!!!
