Auto align buttons when changing window size
Hi there,
is it possible to auto align selected icons (compare + show unique/double buttons in my case) to the right of the window and when you resize they just "move" to the left instead of hiding in the (double arrow) drop down menu?
thanks,
manuel
Put a Spacer before them, right-click it and set it to Full Width. It will use all excess space without pushing anything into an overflow menu.
Awesome! i'm stunned as usual how flexible Opus is.
Thanks,
Manu
