Automated Column width
I set my columns as shown below for all views :
I, then, saved these settings using this dialog:
Now, when I Synchronize folders, the “Name” column gets squished by the “Locations” column and I cannot manually resize the Names column to see more of the filenames.
How should I set up my column widths so that I can still see the filenames when Synchronizing folders?
Thanks,
Ben
Either remove the max=fill on the Name column, or set some of the other columns to Collapse.
Thanks, Leo. that solved the problem.
