Autorun with middle click
hello
If i doubleclick on a device dopus browses it. I like it that way but i also want to able start autorun for CDs/USB-Stick/... easily. I tried to set the middle double click event of the system type "drive" to %1 but that didn't work. It worked with archives (browsing in dopus vs. 7zip/imgburn/...) so it should be possible with drives as well somehow. Is there a way to start the first item of the drive context menu with a double middle click?
You can probably do it using context menu verbs:
gpsoft.com.au/help/opus9/def ... ommand.htm
probably yes but where do i add this? events of the "drive" filetype do not have an effect at all.
Hmm, that seems to be true.
I think you'll have to right-click the drives and choose the Autoplay option (or whatever it's called; don't have a disc around to check).
