I just noticed that there's a new version of DO and wanted to install it. I manually ran "check for update" function from the menu and DO says that my version is current, but it sees a newer version (which is not a beta).
It hasn't been put on the auto-updater yet. You can download it from the website if you want to, or wait for it to hit the auto-updater.
Ah, ok. I thought that I could just use auto-updater as soon as the new version is released on the website. Thank you for information.
