Go to Settings / Preferences / Folders / Folder Formats, locate the FTP entry under Default Formats, and edit it. Then go to the Options tab and see what is set for Color - I suspect it is set to black for some reason. If you change it back to transparent (or use the Reset Page button at the bottom) it should fix the issue.
