Bind "enter key" function to another Key
Hello,
is it possible to buind the action which is on the enter key (open files/enter directorys) to an another key?
I tryed it with the "Go" command + many parameters but it doesnt work ;/ ,,,
-XT
Create a button with this command:FileType ACTION=dblclk
Hey thats good :wink: .. i think i have to studdy the manual more..
I add an adition to that command
Select FIRST
so now ehen you enter the directory you can hit the button again to enter the next directory, without the select first command it was not possible .. i'am good or what?! :wink:
thanx for the help ..
