Bookmarks in top shortcut toolbar?
How do I do this?
I want to put one of my favorites I used often in the topbar
There's an app called clover that does this related to file exploring
Does directoryopus support this if so how do I enable?
You can make a button to that path. Right-click some empty space in the toolbar, choose "customize", another right click, then > new > new button. You can edit that new button then (another right click / "edit").
Then you copy your path into the field "function". You could also define a shortcut for the button.
When you're in Customize, you can actually drag a folder (or program) on there directly. :grimacing:
I did exactly that, but for some reason my button is all the way on the far right
Oh nevermind I figured it out,didn't know about spacers
this is what I did first before abr recommended the other way :slight_smile:
.. learning as you go. And we're experiencing it live. :sweat_smile:
oh sorry this is what I was doing originally
Didn't realize you meant this:
