Bug... Columns changing size when using "F5" to refresh
ive been having an odd bug the past few weeks.
when i use F5 to refresh a folder the columns change size from what where they are set in the Folder formant to being shrunk down considerably. see the screen shots below. it doesn't always happen, but seems too about 85% of the time.
generally im refreshing this way after move or copying something into a dir an im noticing that the size is column has note fully updated even thou the copy\move has completed.
not sure where to start looking as to what could be causing this.
before freshing...
after an F5 Refresh...
this the folder folder format i have set for this particular folder
could it possibly be an interference with have a custom max column width set??
any ideas on what to check yall?
thanks
x
Could you save that as a Favorite format (can be done via the Save button in the bottom-left corner of your screenshot), then zip and send us this file:
/dopusdata/Formats/defined.off (paste that into a path field and push return to locate the file).
That should let us try with the same format.
sent.
ill add nearly all my save folder formats, around 12 of them on a quick count, have custom, or rather, max width sets to handful of fields. it seems those are the columns being affected.
