Bug with sound path under vista (xp i don't know)
good evening all, tonight i try to use sounds with dopus to see just if it's cool, but i find something weird, yes, it seems that dopus what to have sounds in the windows\media directory because if i specify a wav with a another path it doesn't keep it and reset to windos\media, can you confirm this.....argh...bug ? :wink:
Were your sounds in the C:\Program Files\GPSoftware\Directory Opus\Sounds folder?
resource.dopus.com/viewtopic.php ... dia+sounds
