bsp362
March 22, 2012, 7:43pm
1
Hi,
During the last days I've been trying Dopus and I would like to know if it is possible to create a button on the toolbar to open XP's control panel in a lister?
Another question: Is it possible the have the background of the lister changed (colour or picture) when a filter is on?
Thanks for your help
Bob
Leo
March 22, 2012, 7:48pm
2
Does go /controls work on XP?
(Or just type /controls into the path field to try it.)
bsp362
March 22, 2012, 8:02pm
3
It's work perfectly... thanks.
Do you have another good idea for the filtered background?
Leo
March 22, 2012, 8:49pm
4
You can configure the filter bar to always be visible when a filter is active. I don't think you can make the background change based on that, though.
bsp362
March 22, 2012, 9:08pm
5
Do you think it is possible to change the look of the grid (colour, line or off) when a filter is applied?
bsp362
March 23, 2012, 10:01am
7
hi Leo
Please tell me where can I find information like "go /controls" in the user guide or else where?
Thanks
Leo
March 23, 2012, 10:13am
8
Not sure which information you are after, but I guess it's one of these pages:
[ul][li]Creating your own buttons [/li]
[li]Go command [/li]
[li]Folder Aliases [/li][/ul]
