Button to add AND delete the same string of text
got me some nonworking button code here:
I'm trying to have the user type a string they want removed from the selected file.
The string is then reapplied to the beginning of the filename.
@set var={dlgstring|Enter Series and Season}
Rename FINDREP PATTERN="($var)" TO "~" AUTORENAME
Rename PATTERN "." TO "($var)." AUTORENAME
@NODESELECT
help?
You just need {$var} instead of ($var):
@set var={dlgstring|Enter Series and Season} Rename FINDREP PATTERN="{$var}" TO "\~" AUTORENAME Rename PATTERN "*.*" TO "{$var}*.*" AUTORENAME @NODESELECT
Thank you sir.
Need glasses.
