Hi All,
how to create a button that does.
open c:\temp folder in left pane and c:\temp folder in right pane directory opus.
hope you can help me out!
Hi All,
Go C:\temp DUALPATH C:\temp
or if you want to open the Windows temp folder in both
Go /temp DUALPATH /temp
it works thanks for you help
