I'm using the 64-bit version of Dopus and Nikon NEF raw images do not display. Does the plugin work on x64? Thanks
Not yet, sorry.
Any timeframe for this? Shouldn't this be a simple recompilation?
None that I feel comfortable guaranteeing as I have a a lot of other work going on at the moment.
For most code, yes. For the DCRaw code, no. I've decided to re-write the plugin to call DCRaw.exe as an external program instead of converting it into a library that the plugin uses internally because it has proven far too much effort converting the DCRaw updates into proper library code, given the way DCRaw is written. That will take a bit more time than clicking the 64-bit checkbox and compiling.
