Can built in alias' be deleted?
Is this possible?
I am often going to a wrong alias as built I one is similar name to the one I want.
I also want to reuse them for my own purposes.
.e.g /template is not available to me.....
Gratitude.
They can't be deleted and there are things that depend on some of them (including /temp) which would break if you could.
Try a shorter name for your alias and it should get priority. /t /te /tem should all work if the aim is minimal typing into the path field.
