Can hovering be made to work on jPEG2000 images?
When I hover over an image file such as a jpeg in list or details view as you know a popup of its image shows by the mouse pointer.However as you know this does not happen for jPEG2000 images. I'm aware that this is dealt with via a plug-in and read the information that it shows on hovering and/or thumbnail view and in the the viewer (so this is the OR case). Can by some means the hovering action be made to work with jp2 files?
You probably just need to add .jp2 (or whichever extension your files are using) to the Images file type group:
