Can I create a hotkey for a specific lister layout?
I know I can put a drop down list on the toolbar; I've done that. But I would still like to hotkey directly to a specific layout. I'm using DOpus 9. Thanks for any help you can give me.
Go to Customize -> Keys, create the hotkey you want (make sure you set it to System-wide if you want it available outside of Opus.)
Then set the command to Prefs LAYOUT=xxx where xxx is the name of the layout. And don't forget, if the layout name contains spaces it needs to be enclosed in quotes.
Thanks, Jon. It usually takes me several tries to get something to work on my computer. Not this time.
And this works a treat in 13! (All these years later)
Using it so I can trigger different listers from my Streamdeck, so awesome
